tranny work??
tranny work??
looking for someone to swap a phantom grip lsd out of a bad d16z6 tranny and into a good d16z6 tranny will bring the tranny to you anytakers please call 813-298-3149 ask for nino thanks
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Originally Posted by BoogieDown
phantom grip is not good if you make any sort of power. get an OBX diff or quilfie the gears are much stronger
OBX?
Quaife all the way. But Mike is Janky so I'm surprised he didn't just weld the gears
Thanks for calling me
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
well the only reason why a phantom grip is getting swapped in is cause thats all i have at the moment....
*R.I.P. THOMAS CRISTIANO "PAPA" MAY7,1952-NOV.7,2005*
For your tuning needs Call JAP DAN
I was told they where close if not the same. http://www.d-series.org/forums/showthread.php?t=25241
ok i know that this lsd sucks... and that Quaife is better then all others out there... i just need to know if there is anyone that could help me, by removing this lsd that i have in my tranny now and putting it in the other tranny i'm getting.... so any want to take the job??
We can do it.....but you wouldn't call us
Chavez Motorsports
Chavez Motorsports
You can do this yourself. Its not hard. Putting the LSD in is easy just keep everything assembled when taking the main and countershaft out. Lay in down flat togegher in one piece. Keep track of your bolts. Thats all really. To me the hardest part is putting the case back on. I always have trouble with that.
sure its not?!?!?!? i mean i had one for over 3 years in a tranny and auto-x'd it and drag raced with over 300HP, and never had a problem. its all in the install.
i would NOT use an OBX eveR!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
