Hmm, few odd problems..
Old Sep 10, 2005 | 09:19 AM
Drivermod03's Avatar
Originally Posted by Jaso0on
On another note, wtf is Jamie doing up at 7am? Usually you aren't up until about 5pm or dinner time, whichever comes first
Going to work...Damn you have a short memory....Its been atleast 3months since Ive slept in
Old Sep 10, 2005 | 09:23 AM
Pennywise's Avatar
why so serious????
jason ur already havein problems with the del sol... ur luck is the worst
Cornbread Crew member #754
Old Sep 10, 2005 | 10:26 AM
Jaso0on's Avatar
Is now ballin!
LOL, they aren't big problems, and they don't affect the way the car runs at all, still runs perfect I just hate having a check engine light on, and shit being done half assed so I'm trying to get everything back to normal.. Hell for what I paid for it, I'm not complaining at all
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Sep 10, 2005 | 10:37 AM
94EG_Hatch's Avatar
watr line is for the thermo idle valve under the TB it should have two lines the one your missing should run under the intake mannifold. You can block it off but ot will idle funny it adjust for heat like in a LS1. The PCV problem seems to be a check valve, is it reversed ??
Old Sep 10, 2005 | 10:54 AM
Jaso0on's Avatar
Is now ballin!
Nope, its not reversed..
I'm going to just pull the intake manifold off to look for that water line, I've got a y8 manifold that I need to throw on here anyways..
Old Sep 10, 2005 | 11:11 AM
94EG_Hatch's Avatar
blow in the valve see if its working. Make sure nothings clogged. Seems like its backwards. Iunno id have to see how shes setup. unless you have internal issues and your getting a leak and when you add the tube youll too much of a vacum in the wrong spotmake sure the lines are in the right spot.
Old Sep 10, 2005 | 11:14 AM
  #17 (permalink)
Jaso0on's Avatar
Is now ballin!
Well what do ya know, the pos valve is completely clogged, no air came out when I blew into it.. I'm gonna get a new one later and throw her in and see how that goes..
