motor breaking up
when is that last time you had a tune up? cheapest thing would be to change the cap rotor and plugs, i had the same problem, changed the cap and rotor and ran fine. cap and rotors usualy have to be replaced every 30k miles. as the air gap increases b/t the contacts and rotor, its increases the resistance creating a bigger gap to jump , which can cause misses and breaking up like that.
PS be careful taking the rotor out, dont strip the screw like me.
and also if it hasnt been changed in awhile it might not want to come off, i had to break mine piece by piece to get the rotor off be carful doing that also so you dont damage the shaft.
i have that same motor in my DA. good luck.
and also if it hasnt been changed in awhile it might not want to come off, i had to break mine piece by piece to get the rotor off be carful doing that also so you dont damage the shaft.i have that same motor in my DA. good luck.
Originally Posted by lzylst
You didn't say if you are FI. If you are FI, having the correct heat range and gap on the plugs is very important.
i have changed plugs twice the wires cap rotor and today the car complete cut out and im fouling plugs like a bitch second set of plugs in 2 weeks thats just not right im guessing its the dizzy gone bad no im N/A
toooooo RICH! prob drops below 10's at 5k.
