motor breaking up
could be cap,wires,plugs,rotor,fuel filter,fuel pump,ignition module just a process of elemination(spell) i had the same thing wrong and the last thing i checked took a shit the ignition module
R.I.P. Mom, Dad, and Martin Capell Jr.
1) 1990 CR-X DX-Sold
2) 1989 CR-X SI-Traded
-----OBD-1 LOVE-----
3) 1993 Civic EX-Totalled
4) 1994 Civic DX-Sold
5) 1993 Integra LS-Sold
6) 1992 Civic SI-Totalled
7) 1994 Civic CX-Traded
its not cranking Up now ? Are you getting enough fuel ? main Relay going bad ? If your Dizzy is all good then check your plugs again. If your fowling plugs that fast, your getting ALOT of fuel in there saturated plugs wont spark. You could have a wide array of issues. Last time when you filled up did you fill it till the pump was clicking and keep pumping ? Ive had Customers pump and pump and pump and fill their EVAP system and the car wouldnt crank had to remove the charcoil canistar and dump out the fuel. Breaking up is either ign. or something in your cylinder is stopping your spark !
