SOHC Vs. DOHC
Old Sep 5, 2005 | 05:55 PM
SmokinS13SR20's Avatar
That ginger...
Question SOHC Vs. DOHC
I was thinking and couldnt think of a reason why DOHC whould be better than SOHC if you have 16 valves in both engines.I need some help here my brain is begining to fry....like my tires......
Thanks, Joe
Old Sep 5, 2005 | 06:01 PM
na200whp's Avatar
Powered by BOOST
dohc= better flowing head/ more aftermarket support /and more power to start with.
sohc= cheap due to already being in car.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Sep 5, 2005 | 06:04 PM
That ginger...
Do you care to explain how it is a better flowing head?Also, im not talking about having more parts for it. Im basically referring to how it makes more power if it has the same amount of valves...
Old Sep 5, 2005 | 06:05 PM
95gainfla's Avatar
smokes weed...everyday.
sohc are cheap as hell and easy to boost.
dohc are great for NA, but boost well too(just more expensive)
I <3 RooR!!!!!!
Old Sep 5, 2005 | 06:06 PM
NChatch's Avatar
i stepped on my weiner!
a few other things like for example the ability to have or already have a crank girdle like on the b18c1.
also more torque from simple displacement and stroke
if going turbo, the lack of head lifting issues as is with sohc's.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Sep 5, 2005 | 06:15 PM
That ginger...
cmon guys thats not what im asking. im asing *on a stock motor* HOW is DOHC better than SOHC if they have the same amount of valves
Old Sep 5, 2005 | 06:17 PM
na200whp's Avatar
Powered by BOOST
the B series heads have a better port design and flow more air in stock form than most worked (ported w/ performance valve job) D series heads. the other plus is the dual cams allow for more fine tuning of the power band.
K series on crack
S D M
Old Sep 5, 2005 | 06:21 PM
That ginger...
Thanks man lol, so therefore, if there DOHC didnt have a better flowing head design, then a SOHC would be as good as DOHC, if the amount and size of valves were the same?
Old Sep 5, 2005 | 06:24 PM
BG-33P_Hatch's Avatar
Back in the Game
More Horsepower, Torque and just a better motor cause it aint stock ...valves arent everything man. Never mind now good job for understanding (not being sarcastic)
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
Old Sep 5, 2005 | 06:27 PM
na200whp's Avatar
Powered by BOOST
i guess . the B series motors were more performance minded in design. the intake is better ,bigger t/body ,and higher compression . the d series is more gas friendly w/ less race inspired design.
K series on crack
S D M
