SOHC Vs. DOHC
Originally Posted by na200whp
i guess . the B series motors were more performance minded in design. the intake is better ,bigger t/body ,and higher compression . the d series is more gas friendly w/ less race inspired design.
R.I.P. Kevin Gonzales Aka Slo_Si
You will be missed by many.
R.I.P. Robert Kolp Aka 00ek
You will be missed brother
R.I.P Jake D Aka Cold_Beer
you will be missed brother
ok you go out and spend lets say $4000 on a FULL gsr Swap which is the most common swap. and get about 140-145 WHP
Now you can take say a JDM D15b ($800) for full swap. throw pistons,rods, and a crower stg 2 kit, ($1000) and a decent header and aftermarket intake manifold ($800).and be making around 140-150 whp with good tuning. and prolly save $1000. im definetely not putting down DOHC There a great motor but in (MY OPINION). you can make a SOHC just as fast and spend the same amoutn of money. and have better gas mileage.
But like i said if you want to just swap a motor and not do any internal work. and be quick go with a DOHC.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
yea i understand that im just saying money wise u can make a SOHC just as powerful as a DOHC but in my opinion a SOHC would be more reliable. but like i said before if you arent into doing work for power then definetly swap the DOHC and be done with it. me i like to get power by building.
but very true with the gas mileage and a heavy foot +1
Guest
Posts: n/a
A SOHC motor just does not have the same potential that a DOHC will have, due to more displacment, better head design (Being that it IS DOHC, and has much better flowing head), Better R/S ratio, and more aftermarket support.
Seriously, how many SOHC motors have you seen make 300whp on 8psi?
