crx owners (water Leak)
Old Aug 26, 2005 | 12:33 PM
91 TURBO's Avatar
im a ricer!!
thats exactly where mine leaks to. i was reading on the net, that if you follow the black strip on the roof that goes from the windshield to the hatch, that where it meets the wheather stripping for the hatch right under that is where it usally cracks.
Old Aug 26, 2005 | 03:15 PM
dr3d's Avatar
"The Hand"
that was my thought because i dont have a sun roof but how do you get that strip off to check under it.
i know of three other crx's that leak in the same spot and it has us all scratching our heads like monkeys.
i also heard that the rear wiper sprayer could be the problem but that is not the problem because mine is tight and the hose that hooks to it is not leaking.
i am getting to the point where i am going to have to gut the interior out just to see if i can find it.
all i can say is this really sucks. we should all get to gether and see if we can find these damn leaks.
Old Aug 26, 2005 | 03:18 PM
kender's Avatar
gadget man
the sunroof has a drain tube on all 4 corners that allows any water to exit the underside of the car so I doubt its the sunroof. I would look into the weather stripping, I have the same issue and if I were keeping the crx I would replace all the weather seal in the hatch area.
U.S.S.A Crew Member #001
Old Aug 26, 2005 | 03:26 PM
dr3d's Avatar
"The Hand"
but what about the rain gutters on the roof how do you get those off with out tearing them up so i can see if there is a crack under them
Old Aug 26, 2005 | 03:34 PM
dohcvtec's Avatar
You boys like Mexico!!!
under the rain gutters is just the body of the car....so yes id say its weather stripping
Springhill
22" Nothing less
Old Aug 26, 2005 | 03:36 PM
dr3d's Avatar
"The Hand"
but how would you go about taking them off without damaging the strips
Old Aug 26, 2005 | 03:41 PM
  #17 (permalink)
dohcvtec's Avatar
its as simple as popping one end up and sliding it off
Springhill
22" Nothing less
Old Aug 26, 2005 | 06:55 PM
  #18 (permalink)
{{HEAVYDUTY}}'s Avatar
If you doubt me,try me!!!
the drains are prob. clogged they are in the rear behind the plastic's if thse are good then my rear washer sprayer also leaked and ran down the hatch to the tail lights but also you might wanna put new hatch seals on.
need a realestate agent contact me.
Run your car not your mouth!!
2006 GSXR 1000
1988 CRX SI "All Motor"
"not 4 long"
It's my dick and i'll wash it as fast as i want to!
Let me guess? You missed a gear!!!
FUCK BARNEY'S!!!!!!!!!!!!
Old Aug 27, 2005 | 04:24 AM
  #19 (permalink)
TSX24L's Avatar
weather stiping along the back glass window fixed mine.
