b17 turbo
is this a good idea...has anyone done this....what were your results...was gonna bolt a turbo kit on a stock motor with only 5 to 7 pounds daily.....opnions are appreaciated
that motor should have not problem with that little boost. just check to make sure you have a "healthy" motor. good compression not blowing any type of smoke.
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Originally Posted by integrex
yea motor is in prime shape....what whp do you think it would make?
and i heard mtber is the mother effin man on tuning.
just kidding
its n/a right now but i have skunk2 cam gears and a b&m fpr
other then the turbo kit is there anything else i should get for that lil of boost
not really looking to crack the motor open yet (will on next rebuild but if its not broken dont fix it ya know)
umm I would say get some dsm 450cc injectors that way you have some room to move around. and tuning
Im mainly a sinle cam kinda guy, hence my H22, But the comp. ratio vs. volume per per cc is profound, From My personal experience no more than 5-7 lbs. And I stand to be corrected But i stand true. I cranked a 11-12 lbs ond poped it.
But Just a redneck putt'in his 2 cents in. Good Luck
And slowerthanyou is on the money
And When It Rains.. It Pours..
Roughneck Refab .Inc
I understand you are voicing your opinion.... But a stock motor can handle more then 7 psi on most avg sized turbos. All it takes is proper fuel management & tuning.
