LS/VTEC vs.B16a
Old Aug 24, 2005 | 01:08 PM
fathead's Avatar
I'm aLL mOtOr I sWaRe ;)
Originally Posted by Blown99civicSi
To anwser you question, the LS/VTEC will be much more fun driving from stoplight to stoplight, due to the increased TQ, But the issue you will have is REV's the LS bottom-end was only ment to rev to 7.5K, the B16 head doesnt really start to flow untill 6-7K, If you do it the right way and build it the right way, using good parts. you can aleave this problem, but then you are still left with a bottom end that has a kinda shitty rod/stroke ratio, The b16 has the best, then the GSR and so on, The RS/ratio boils down to reving range,and no matter what you do, the LS will never be able to rev as high as say a B16/B17 or even the GSR, Not saying that people dont rev the piss out of there LS/VTEC's but thats were the reliability issues come into play. All in all the LS/VTEC is not the greatest motor to just throw togeather and expect big HP numbers, all it is, is a Poor mans type-R, without the reving range, But throw a turbo or nitrous on it and it becomes something totally diffrent, This is comming from a person who just sold a 425HP LS/VTEC 11:9:1 comp Nitrous feed motor to someone in GA. He loves the motor... It all boils down to what the car is needed for and what the future holds for it, Boost?? NA??? Nitrous?? Plan ahead.. Good luck..
i hate to tell ya but the ls bottom end can rev just as high as any b-series as long as the oil pump can support it. the ls motor stock from honda doesnt rev high because the head cant support high revs.... ive seen lsvtecs rev to 10.5.... and if you want to be ridiculed even more ask 200nawhp.... hes making like 230 n/a with a B20 block which if you know has the same stroke as an ls but only diff is the bore... i want to see this lsvtec you built and i want videos and actual testimonial, cuz from what it seems you dont know what your talking about that well...
RIP Kevin "Slo_Si" You'll be missed by everyone who knew you my nigga.... I'll see you soon man...
Old Aug 24, 2005 | 01:11 PM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
as far as a daily goes.... fuck a b16 they have no bottom end. daily id have to give it a ls motor all day. and turborotarty ur gay.
lol that guy said b16 has best rod stroke ratio...... FAG
tamparacing.com
Old Aug 24, 2005 | 01:18 PM
4dorteg's Avatar
Allan works as well
I have to disagree if a ls/vtec is built properly it is just as reliable as a b16 and will easily rev to 8500. If you have a b16 and rev the piss out of it everyday and beat on it all the time its not going to last very long, but that it the same with any motor. There are plenty of people with daily driven ls/vtec that were built properly going on 50k + miles. It has a lot to do with the builder and using the right parts and the rev issues with ls/vtec is all in the rod bolts as fathead stated earlier. USE ARP ROD BOLTS there are 2 different size one's use the bigger one's!
PM mtber on this board and he will agree that if built right the ls/vtec it is a great motor for daily driving or as a weekend warrior. Just remember to get it tuned and use the right parts.
TR salesman..........
Old Aug 24, 2005 | 01:26 PM
INTEGRAJTW's Avatar
yeah im gonna go with LS/VTEC, going to a b16 im loosing alot of torque, so any suggestions with what setup, im thinking to use the b16 pistons, and i'll get the ls/vtec conv. kit, to build it up properly how much do you think it will run me, im not worried bout spending the money. im just think if i do the b16 im gonna be dissapointed with the torque loss
Old Aug 24, 2005 | 01:30 PM
4dorteg's Avatar
Allan works as well
def use b16 pistons for nice comp. if you havent purchased a head yet I'd go with a gsr just because of the extra .2 points in compression and nobody can really prove which head flows better (b16 vs gsr) it's all opinion. type r oil pump, water pump and ARP ROD BOLTS!
Old Aug 24, 2005 | 03:11 PM
TurboRotary's Avatar
Mazda > Honda
honestly.. alot of trq on a FWD isnt always a good thing.. not unless your car is set up for it. Youre gonna need good tires, traction bar, struts, ect. to put that trq to the ground.
Honda Know It Alls Hater Crew Member #0000001
Old Aug 24, 2005 | 04:23 PM
  #17 (permalink)
SoOo HigH's Avatar
sell me ur b16 short block and u can have money to buy stuff for ur project :T
Old Aug 24, 2005 | 04:24 PM
  #18 (permalink)
Blown99civicSi's Avatar
EFI Tech/Tuner
You guys totally missread my post, I said that IF you build it right than its a awsome motor, but if you just plan on slaping it together then its not going to be able to rev high or last long, It also doesn't help that the B18B/A's dont have oil squirters below the pistons to help cool the wrist pins and piston bottoms. I myself love the LS/VTEC motor, thats why I built one, I only sold it due to medical bills and a new little girl..
As long as you replace the rod bolts and get a VTEC oil pump and spec it all out RIGHT the motor will be cool, BUT again, I will still point out that the Rod/stroke ratio is not the best it can be for high revs.. Sorry for the mix up guys, mabye I worded it wrong in my last post..
Old Aug 24, 2005 | 05:19 PM
  #19 (permalink)
fathead's Avatar
bench flow test prove the b16 flows better!
Old Aug 24, 2005 | 08:51 PM
  #20 (permalink)
INTEGRAJTW's Avatar
so high" how much you wanna give me for it? im thinkin of doin b16 for now and then throw on a turbo not sure tho, how much of a diff you think i would feel between the two? my boy up north had both and he reccomond the b16 over ls/vtec all day
