honda civic with idle surge,HELP!
Old Aug 23, 2005 | 07:20 AM
bcarter82's Avatar
Harbor Rat
Exclamation honda civic with idle surge,HELP!
95' civic lx 1.5 and the idle surges somtimes from like 900 to 1200 at idle what could this be i heard its common how is it corrected ............thanx
It does what its told!....it puts the lotion on the skin!
Old Aug 23, 2005 | 07:26 AM
Cold_Beer's Avatar
Rockin' 4 more Cylinders
IS it throwing code? It could be a couple of things . Break in a Vacuum line, Iacv could be bad etc.
RIP Robert Kolp aka 00ek 4/07
_Jake D
Old Aug 23, 2005 | 07:28 AM
methree's Avatar
loser x.x
+1 for vacuum or iacv. mine did the same thing, it was the iacv. just unbolt it from the back of the manifold and spray some carb cleaner or something in there, if thats not it you have to get another one. or at least thats what i did with mine..
i dont know why people dont take me seriously....now wheres my crack pipe
Old Aug 23, 2005 | 07:38 AM
bcarter82's Avatar
Harbor Rat
no codes and what is the iacv whats it look like where is it located,its my girls car,it runs fine it just oisses her off which in turn means i have to hear it.
Old Aug 23, 2005 | 07:46 AM
methree's Avatar
loser x.x
ok, iacv valve has a white thing on it with a plug...umm i dont know how to describe it. it has 2 10mm bolts holding it on. its directly on the back of the manifold. if thats not it try any vaccuum lines that may not be connected.
Old Aug 23, 2005 | 08:10 AM
bcarter82's Avatar
Harbor Rat
thanx alot for all your help
Old Aug 23, 2005 | 08:20 AM
methree's Avatar
loser x.x
no problem
Old Aug 23, 2005 | 08:22 AM
methree's Avatar
loser x.x
although, if its not throwing any codes its more than likely a vacuum leak, just a little fyi. check vaccuum lines before you go yanking the iacv off
Old Aug 23, 2005 | 08:39 AM
bcarter82's Avatar
Harbor Rat
cool will do,if that dont work ill get back to ya,if thats alright.
Old Aug 23, 2005 | 09:56 AM
methree's Avatar
loser x.x
its cool, post how it turns out later
