Need help with code 4
Old Jul 21, 2005 | 12:23 PM
Yellow Rocket's Avatar
The Big Diehl
Default Need help with code 4
code 4 is the crank position sensor, i was told i can change the sensor and its inside the distributor....i just need to know where in the distributor its at
They say when a shark attacks you're supposed to punch him in the face. Then what, poke him in the eye with your nub.
Old Jul 21, 2005 | 01:27 PM
chi town brat's Avatar
! Ne shab'rud'ni !
hmmmmmmmmmmm why am i thinking that you cannot ... my #1 tdc sensor in my dizzy went out and i cldn't replace it and it is the same for this sensor ... in the manual it stated ... this sensor cannot be replace you have to buy a new distrib from Honda
Old Jul 21, 2005 | 01:30 PM
! Ne shab'rud'ni !
just confirmed it with my friend ... unfor you will have to buy a new distrib or you may be able to find one used ... best of luck cuz they are not cheap.
Old Jul 21, 2005 | 02:05 PM
The Big Diehl
yeah....i bought a new one like 2 months ago and it went out then traded it in for another one and now it went out on me....there has to be a reason why i keep killing distributors on my car.....on the bright side this one is under warranty so i can exchange it still.... i also found out a few minutes ago that the big plug going into the dizzy is all chopped up so now i need to find the 7 wire plug for my car(not much wire left on the old one)
Old Jul 22, 2005 | 09:04 PM
The Big Diehl
reattached the wires and the car is running but any time at full throttle its like it loses fuel.......what could the problem be?
Old Jul 23, 2005 | 06:46 AM
methree's Avatar
loser x.x
is it all the way while in full throttle or does it occurr at a curtain rpm?
i dont know why people dont take me seriously....now wheres my crack pipe
Old Jul 23, 2005 | 05:15 PM
The Big Diehl
i only drove it down the street then parked it.....it did it as soon as i gave it full throtlein first gear....it wa saround 3500 to 4000 rpms
Old Jul 23, 2005 | 08:47 PM
methree's Avatar
loser x.x
maybe you got a bad distributor.if not, ecu or timing could be the culprit. maybe new spark plugs or something. could be a number of problems with the description you gave. what codes are you throwing now?
Old Jul 23, 2005 | 09:03 PM
The Big Diehl
Old Jul 23, 2005 | 09:44 PM
methree's Avatar
loser x.x
lol, thats another distributor gone. try another one. if your dizzy keeps messing up its from heat or wiring.
