sohc turbos.........
who all has a sohc turbo and how do you like the performance of it,i was thinking of boosting mine soon but wanna see who all here is already boosting a sohc,and what the best set-up is.i dont wanna spend to much something cheap but decent,just enough to run at like 7-9/10lbs cause im wanting to go dohc in a few months after i get some cash saved up w/this new job.but if im running at low boost i dont need any fuel management do i?just want to play w/ it for a little bit.
my turbo doesnt have cams period and boosts 18psi no problem
ASE: Brakes
ASE: Brakes
theres really no cheep turbo kit , for two u will always need some sort of fuel managent, for three i had a t/3 t/4 50 on my sohc that made well over 200whp it cost me like 2k but it was well worth it. Just my .02
Why not just wait until you swap?
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Mazda 2 Forums
if plan on boosting any motor i would run an upgraded full management regardless...on mine with 8 pounds i was going to run 450cc's and a 255 fuelpump, chipped ecu..completly stock motor, and a cheaply put together kit. But thats all sold, and doing a build on a SOHC.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
you'll need fuel managment... you could use a 12:1 FMU but don't reccoment going over 7-9lbs... stock injectors may even hold up to a small turbo, but DSM 450cc's are cheap.
I have both DSM 450's and an FMU along with a turbo manifold/downpipe and turbo I could get rid of if someone brought cash
You would be missing IC piping, IC and bolt up your exhaust you would be done.
200+ MPH Club
1000+ HP Club
200+ MPH Club
1000+ HP Club
AIM: TurboedTrip
