sohc turbos.........
Old Jul 18, 2005 | 04:11 PM
BACON's Avatar
VALE TUDO!
^^^^ this man knows the once cam turbo setup. Best I've ever seen!
Your car club is gay...
Old Jul 18, 2005 | 04:15 PM
mtber's Avatar
Originally Posted by pheobo
you'll need fuel managment... you could use a 12:1 FMU but don't reccoment going over 7-9lbs... stock injectors may even hold up to a small turbo, but DSM 450cc's are cheap.
I have both DSM 450's and an FMU along with a turbo manifold/downpipe and turbo I could get rid of if someone brought cash
You would be missing IC piping, IC and bolt up your exhaust you would be done.
Fmu = crap
Go with 450cc injectors (make sure you wire a resistor box if you need it for the injectors you use). I also recommend a chipped obd1 ecu & some tuning so that the setup lasts more then a week.
Old Jul 18, 2005 | 09:25 PM
lowoctane's Avatar
Professional Dumbass
Originally Posted by mtber
Fmu = crap
agreeed.
fmu = crap, useless wires....
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
