Please Help My Headache Go Away
Old Jul 12, 2005 | 12:12 PM
vtectuner2204's Avatar
Default Please Help My Headache Go Away
I recently did a b16g2 JDM swap into my 1996 civic EX and I did a complete swap motor trans ECU did not do the wiring harnes used a jumper wire.
I now have a check engine light on and it says that all the sensors inside the distributor are giving bad readings. I checked the resistance of all the sensors and they all check out fine. It is also saying that it can not find the o2 sensor. but it is wired correct too. Vtec will not engage with the check engine light on and some times it will cut out the ignition at 4000 rpms. If anyone has had this problem your help would be appreciated. I am open to all suggestions please.
thanks for your time.
I have posted this earlyer but still need help.
I got vtec to engage buy shutting down and popping the clutch but then after idle drops goes into limp home mode
Old Jul 12, 2005 | 12:24 PM
Anyone got a p30 working ECU for sale? stock or tuned?
Old Jul 12, 2005 | 01:00 PM
Punkinterviews's Avatar
Chavez Motorsports
I have an OEM JDM P30 ECU......if interested PM me
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
