96 civic..NO spark
Ok, so i was changing my plugs, cap, and rotor, and oil on my car on monday. I did all that, started it up, it ran great, no miss or anything. Let the car sit and idle for about 5 minutes, then it just died, no sputtering or anything like that. It sounded like someone just shut it off. Now it just cranks over and over with no spark. I have changed the coil, and icm, with no luck of getting it started. I tested the main relay (its fine). Im open to any suggestions. please help me.
Edit: it is a stock d16y7, the car has never been messed with.
Thank you,
Derek
Thank you,
Derek
1998 crv daily beater
Guest
Posts: n/a
First things first... are you sure you're getting no spark to all the plugs? Secondly, check the spark comming from the dizzy, check each terminal.
If you are still getting no spark, check your fuses under the dash. Sometimes you can accidently short out the coil and it will cause a fuse to pop. Check all of them.
Good luck.
Good luck.
thanks, im not getting any spark from the dizzy, checked every fuse in the car with a multi meter, underhood and dash... theres power going to the black/yellow wire on the coil
call my shop if u want this problem fix, i do regular automotive as well, i will tell u exactly whats wrong with your car..........i have people from TR come to my shop with this problem all the time...........VIC call me if interested in fixing
Need Honda/Acura Parts? PM me
If i can't find it, I know someone who can.......
just got the call, its running. Seems some of the parts i replaced were bad
Something in the car fried the coil again, back to CMS to look thru my wiring. On another note, when i pulled over when the coil cut out, my cat was glowing red, is it clogged?
