BIG THANKS to MTBER!!! (dyno sheet inside)
Highest injector duty cycle I believe it was seeing was 52%.
insanecivic are u the guy with the white civic that i've seen infront of collin shop a few times.when i saw it there was no interior and a very clean car man,and very nice numbers man.
john tell me u did the dyno jump start trick i taught u
great nuymbers chris, glad to see its working out for u finally. just dont get too greedy with pump gas because we all know your gonna turn the boost higher
Originally Posted by spectacle
I'm impressed. good shit man
+1
Chris is using an Blitz SBC-ID I belive
Hondata saves lives
Hondata saves lives
Originally Posted by mtber
Keep in mind that the intake temps were very hot & I could not turn off the car due to a battery that was completely dead. I am sure the motor was seeing heat soak conditions.
If I had more time on the dyno & a working battery, the tq & power band wound have been a little nicer. We spent a good 30-45 minutes just trying to resolve the boost spiking issue.
Sweet, now only if we had a working battery when I tuned it LOL
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Yes, I am using a Blitz SBC-id for now, but hopefully I can get my other boost controller up on EBay soon, and use that money to buy a profec B (spec I)
Im also going to try a larger wastegate spring, and possibly also a larger dump tube to try to get rid of the boost spike/creep...
