Just a lil S2K, i worked on yesterday
you might have some trouble tuning cam gears on that thing as it is chain driven. thats probably a fun street car.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
mugen and toda just came out with them but they are about as much as an EMS set up, so hes kinda torn
he was gonna get a diff and beef up the rear end a bit but has decided on tuning after the brick wall of 50hp for about 1200-1500 rpms was in his face
but it really did what VORTECH said it would do, when the numbers were corrected it actually made a tad more but this was the actual street numbers.
we didnt add, drain, or put any type of colder fluid, why you might ask, cause its a bitch to remove in the fenderwell, and theres no drain valve on it, there will be next week after we put one in. i would like to run some really cold water thru it next time just to see the improvement
and to those who think these things build boost instantaneously......youre wrong!!!!!!!! 2psi@3900rpms, 4 psi right before vtec, its kindof a pain in the bottom end.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
they would be a pain in the ass to adjust. make a pull , then tear it appart ,make a change, and put it back together, make a pull....and so on.
K series on crack
S D M
K series on crack
S D M
Originally Posted by NChatch
right now all i see is EMS for up to 02' ans 03' im wanting to know if it will work on the 04, if so i wanna get it ordered this week
I would call aem & speak to one of the AEM techs to confirm
thanks john, believe it or not the 02,03,are slightly different form the 04, we kinda found this out the hard way, some sensors are different, and some of small thing but it led me to believe there was more, and when the 02-03 kit didnt come with a different MAP/fuel controller, i knew there must be some significant difference.
thanks for the heads up,
heck i was gonna see if 60-1ek could do some kind of harness swappy deal thingy to make somethin work if they didnt have it out yet!
owner/operator
owner/operator
