Tranny fluid????
Originally Posted by Si-R Trickey EF9
I had 10w30 in my S1 tranny with a grind in 3rd. I then put in the GM Syncomesh WITH fricton modifier (its a rearend differential fluid for all GM's sportscars, mostly in the Corvette) and it cured my gind. Ever since I swithced to that stuff, I have never used anything else. I recomended it to all my friends, and now thats all they use. One buddy of mine wanted to try something new, so he got some of the Royal Purple tranny stuff and he hated it, and went back to the GM syncromesh. SO, I recomend the GM syncomesh with friction modifier. Hope this helps.
~Clinton
~Clinton
+1 on the synchromesh with friction modifier
is there any particular weight that you guys are using with the GM syncromesh modified?
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
I didnt think it came in different weights
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
John, do you know of anywhere locally who stocks the syncro mesh???
the chevy dealer does next to hondaland
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
KJ built
ALPHA TUNED
....Just playin I use synthetic motor oil .....works great
