motor swap horror stories
Old May 17, 2005 | 10:40 AM
rangcrx's Avatar
engine building &best
wow you bent valves after one over heat?glad i dont have any bad tales i guess cause i check,check and check 4more times on everything
i love AUTOZONE
Old May 17, 2005 | 03:20 PM
Juicy_J's Avatar
clownin since 81'
Originally Posted by aka5000
I did my first rebuild a couple years ago in my crx. It started out when my radiator had a crack in it and a friend of mine had a spare. We installed it and went for a drive later in the afternoon. During that drive, my waterpump went out and my car overheated and I bent a couple valves. YEAH.... We towed it back to the house, ate some xanax and started the rebuild. You can only imagine what happened next. "Do you remember where we put that" "Do you remember where this bolt goes" and so on... Needless to say, when we were finished we had extra parts all over the place. I am glad to say she ran up until the the swap.
The XanaX Mechanics
******Attention******
Do not try this at home
that was funny
Any electrical/voice/data work needed or questions please feel free to PM me.
Wiring is no hobby, call an Electrician.
myspace page
Old May 17, 2005 | 03:35 PM
alri0085's Avatar
Scuderia ALRI
I forgot to tune my motor, it lasted 395 miles, no joke. Also, on the same car I installed a motor, started it up, it smoked like snoop, pulled it out. total running time: 60 seconds.
Old May 17, 2005 | 05:15 PM
coleon's Avatar
RedNeck Refab.Inc
Lehigh Baby, ALL Lehigh
And When It Rains.. It Pours..
Roughneck Refab .Inc
Old May 18, 2005 | 09:23 AM
aka5000's Avatar
Yee-Haw
Old May 18, 2005 | 09:46 AM
TSX24L's Avatar
I think the worst motor swap horror story is when I was using integra mounts and the axles I could never get to sit striaght they where always a bad angle. I never could fix the problem until I replaced the mounts with hasports and relocated back the tranny side mount. A huge headache on trying to save a few hundred dollars. The axles would always rub on the lower a arm or fork. I tried to cut into the fork to allow clearance for the axles to be able to turn also with out letting it rub while turning. Now I have learned how important it is to just do everything the right way or don't do it at all.
Old May 18, 2005 | 02:45 PM
  #17 (permalink)
juiced2ndgenteg's Avatar
I built a nice LS/vtec, never put in aftermaket valves, ran really really good with CTR cams. I swapped in crower stage 3's and ran it for about 3 months, then dropped a valve because of high spring tension and aggressive lobe ramps. Moral of the story: never run "RACE ONLY" cams in an engine with stock valves... It killed EVERYTHING, cracked sleeve, pistons, head, etc, etc. wasted $2k... only thing that was left was the crower rods and a LS crank. now I'm boosted and ONLY run stock honda cams.
Old May 19, 2005 | 08:34 AM
  #18 (permalink)
aka5000's Avatar
OUCH!!! Boys and Girls... Do not do that^^^ at home.
nice expensive lesson.
Old May 19, 2005 | 07:34 PM
  #19 (permalink)
Humpdatbooty's Avatar
I put in a D16Z6 in my old 93 civic out of a wrecked car that i bought for $100. Everything looked fine, except for the dented oil pan. After the swap was done, i was so tired of messing with the car that i didnt bother replacing the oil pan and I was ready to test out the new VTEC motor! Well everything ran "fine" and continued driving the car for about 2 weeks worry free-meanwhile noticing that VTEC just didnt feel right. On my way to class, i was getting harassed by an SUV and decided to take off and get away from the maniacal soccer-mom.. I ran through third in high RPMs and i guess I didnt get enought oil or oil pressure or whatever and slung a rod completely through the block! funny part is-I was planning to swap out the dented oil pan for a good one and give the engine an oil change and tune up after i got out of class that day.
The term "mint" is overused and is said too casually and often incorrectly. Especially on Tampa Racing.
Mint (adj) - (of an object) In pristine condition; as new
Old May 19, 2005 | 10:16 PM
  #20 (permalink)
rebels's Avatar
Shaved Accord
I busted one of my A/C lines when doing the swap and I still haven't fixed it.. I definitely need to coz it's getting hot as fuck out.
I also blew one of the seals in the radiator when I hydrolocked my first motor, and coolant/water would come out the vent in my hood when the vtec would engage.. that looked pretty cool.. kinda like purging but ended very shortly when i replaced the radiator.
nothing else went wrong or bad.. except maybe when i had to fix the ECT sensor
Adam
University of South Florida - Graduate School
