Ignition Coil Bad?
Old May 10, 2005 | 06:53 PM
MR2driver's Avatar
not available
Default Ignition Coil Bad?
I finished swapping the del Sol with an H22A. Motor turns but does not start. Checked for spark, no spark. I read on honda-tech to check the distributer and coil. I checked the primarys on the coil and they ran 1.0 ohms of resistance. I then checked the secondary. Secondarys read at 9.9k ohms. The helms manual I have is for a single cam, but it shows that the primary should run between .6 and .8 and the secondarys should read between 12.8k and 19.2k. This means the coil is out of range and should be replaced. My question is, are the ranges for the single cam the same for the h22a distributer? Do you guys think the coil is bad? I also have plenty of fuel going in. Any other things you think I should check? Thanks.
Old May 10, 2005 | 09:20 PM
{{HEAVYDUTY}}'s Avatar
If you doubt me,try me!!!
either coil or igniter
need a realestate agent contact me.
Run your car not your mouth!!
2006 GSXR 1000
1988 CRX SI "All Motor"
"not 4 long"
It's my dick and i'll wash it as fast as i want to!
Let me guess? You missed a gear!!!
FUCK BARNEY'S!!!!!!!!!!!!
Old May 22, 2005 | 12:51 PM
MR2driver's Avatar
not available
Just to let you guys know, it was the iginition coil. Switched it out. Runs fine now.
HybridSS
Nov 13, 2003 11:11 AM
obituary
Nissan/Infiniti Tech
Oct 8, 2003 03:28 PM
foesicks
Sep 27, 2003 02:39 PM
