LsVTEC or B20VTEC
Old Apr 29, 2005 | 05:26 AM
PantySniffer's Avatar
grippin grain
B20 Sleeves are weak as shit. I'd either go w/ the LS bottom end or Just a GS-R swap instead...Question is vague, what's your budget? What's your goals?
Obsession is a word used by the lazy to describe the dedicated.
GO GATORS
Old Apr 29, 2005 | 06:12 AM
Jaso0on's Avatar
Is now ballin!
Very true, and b20 bottom end parts are expensive as shit! If I could go back, I would just buy a gsr and throw it on a little bit of nitrous, with the right suspension and driver itll bust a 12 no problem..
ls/vtec = moneypit from hell..
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Apr 29, 2005 | 06:38 AM
tranceologist's Avatar
TR Shop Mod
stay away from b20 bottom ends, they r weaker. hell stay away from lsvtec or crvtec. if u want a realiable car, go with something that is supposed to be vtec. less hassle in the long run. they run hard ya, but 30,000 miles is the most ive heard these things last. if money aint a thang u know...
Old Apr 29, 2005 | 06:50 AM
juiced2ndgenteg's Avatar
I'd run a b20 bottom with a gsr crank. use gsr rods and aftermarket gsr 84mm pistons. high revving almost 2.0L gsr.
Old Apr 29, 2005 | 07:59 AM
CRXkid24's Avatar
uh oh
shit i dont care what anyone says...my ls vtec is still running strong and its daily driven.
my car gets mad after 5,500 rpm!
cheeSpec tuned!
R.I.P.
Pablo
Lil John
Mario
Old Apr 29, 2005 | 09:18 AM
rangcrx's Avatar
engine building &best
this is a very good setup,a lsvtec and b20vtec are near the same thay use the same rods and crank just one is a 81mm the other is 84mm...lsvtec is a very good setup when done right and it does not cost much unless you make it cost much.but putting the gsr crank give you lil more reving safty.
i love AUTOZONE
Old Apr 29, 2005 | 09:44 AM
  #17 (permalink)
Jaso0on's Avatar
Is now ballin!
So was mine, but about 40 miles to and 40 miles from work on a daily basis, with a j1 tranny killed it.. Well that, and spraying it
But yes, youhave a very stout setup. I want it!
Old Apr 29, 2005 | 10:07 AM
  #18 (permalink)
mtber's Avatar
Stock b20 sleeves work just fine for most n/a applications as long as the motor is propeprly tuned
Old Apr 29, 2005 | 02:18 PM
  #19 (permalink)
60-1EK's Avatar
Engineer at the source
That is because you either cheaped out on parts, your build sucked, or you didn't tune it properly. Stop spreading false information!!!!!!!!!!!!!!!!!!!
NA200whp = 222whp all motor....STOCK b20 sleeves, reving to 8200 all day long. I have built many all motor setups using both LS and B20 stock blocks. Never had one issue.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Apr 29, 2005 | 04:06 PM
  #20 (permalink)
Cold_Beer's Avatar
Rockin' 4 more Cylinders
and that motor is still running to this day in another car
RIP Robert Kolp aka 00ek 4/07
_Jake D
