Pison Ring Gaping
u always need to check the piston ring gap when assembling a motor IMO. if the gap is too large u know there is something wrong and if theyre too tight they need to be filed. OEM pistons generally dont need to be filed if the machione work is done properly but on after market pistons some people like to run slightly larger or slightly smaller piston to wall clearance which obviously directly affects ring gap. as far as the specs go your best bet is to just call the manufacturor and ask
Originally Posted by SpyderHatch
its just like THAT LIL WHITE PAPER HAS WORDS ON IT
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Originally Posted by LIL_G
Its A Sham Some People Are Assholes-spyder Hatch- Some Pistons Dont Give Those Specs
i love AUTOZONE
i love AUTOZONE
Originally Posted by rangcrx
heheh wow good answer but its not being a asshole its just like a women he always thinks his right
I just get tired of answering the same dumb questions over and over again and usually You guys catch me when im in a bad mood, most of the time when im online im cooling off because i got in a fight with my better half ! lol
"Your audio sytem will not draw enough amperage to drop your RPM's" ok stop posting in here you say you work at CC you telling me you never sold a Mtx amp that draws that much power,if you wish i will be more then happy to hook up my 2 2300x Mtx amps with 2 12" subs and we will see what kind of power will make your rpms drop,and if its a honda i will be more then happy to install my higher amp alt with only 1 battery and see it will still make it drop,damn i just cant believe you said it will not draw that much,and no one cares if you got into a fight with your boyfriend save that for ffa
i love AUTOZONE
i love AUTOZONE
