Modifing for precission injectors question
Old Apr 5, 2005 | 07:20 AM
Preludesitdriver's Avatar
Default Modifing for precission injectors question
I am going to the bigger injector side. I was wondering if what mods do i need to run the 1000cc pression injectors. thanks
Bring it!!! You see that!? yeah me either
Old Apr 5, 2005 | 07:43 AM
Punkinterviews's Avatar
Chavez Motorsports
Get a car that needs injectors that big would be a good start!
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Alpha's Avatar
Does your power level warrant 1,000cc fuel injectors? If you are not making 500+ wheel horsepower you don't need 1,000cc fuel injectors. Precision injectors are machined to fit our fuel rails.
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Apr 5, 2005 | 07:48 AM
yes i have a fully built motorand i am looking to get it tuned at high boost. like 15 -18 lbs. I am aiming at the 450 500 whp range. The reson i ask about the injectors is because I heard you have to modify something on them to fit the honda setup. I havethe h22a
Old Apr 5, 2005 | 09:54 AM
InsaneCivicCoupe's Avatar
Retired Ricer...
I seriously doubt you will make 450-500whp on only 15-18psi of boost, unless you are running some big nasty turbo... What turbo do you have???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Apr 5, 2005 | 09:58 AM
i am running a t3/to4e turbonetics turbo, apexi avcr, waiting on some info on injectors, also have a 2.5 into 3" exhuast straight, msd sci, wires and coil. alot more stuff. just dont want to list all
Old Apr 5, 2005 | 10:43 AM
MacGruber's Avatar
MaDe Of MoNeY
Who's doing the sleave work?
-Mike
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Apr 5, 2005 | 11:07 AM
Retired Ricer...
That turbo may be good for 450whp (depending on compressor wheel) but I guarantee it will take a LOT more than 15-18psi...
When you say fully built motor, what do you mean??? sleeves, rods, pistons, cams, valvetrain, port work, etc.......
Give us some more insight here...
Old Apr 5, 2005 | 02:46 PM
Alpha's Avatar
I have a PT-61S here that will make 400whp - 420whp @ 10lbs - 11lbs you can buy
* IP E-Mail
* IP Face Book
* IP Web-Site
BLUE2KSS
Apr 9, 2004 06:47 AM
