Honda motor guru's, I NEED YOUR HELP!
Old Mar 13, 2005 | 06:56 AM
Jake's Avatar
dýsfuňctiønal
Originally Posted by Cronic
Welp, buy a quart of oil, a compression tester, a 19mm 6pt socket, spark plug socket (5/8") a ratchet, and maybe a 6" extension for the sockets. Unscrew the plugs screw in the compression tester one at a time, and turn the crank over a good 7-10 revolutions or until the guage stops going up, do this with the throttle plate all the way open. If they're all close to the same number, the compression is good. If you really want to get into it, drop a cap full of the quart of oil into the chamber through the spark plug hole, and now check compression again. If it raises a substancial amount, say 50psi, the rings are most likely bad. A compression test should be done on a warm motor, @ WOT. But you can get close results on a cold motor.
Where can i get all this and how much would it cost?
FLeuro
TheCommision
Old Mar 13, 2005 | 06:58 AM
crazyhatch's Avatar
someone's been in here b4
Originally Posted by mtber
Good luck, not many people actually know their shit on this forum.
+1million
Old Mar 13, 2005 | 09:42 AM
rangcrx's Avatar
engine building &best
hey what time you leaving monday im off monday and will love a free ride im in tampa,i got all your tool like Cp tester and what not......question its a whole swap with tranny just asking cause if the sarter is on it makes it easier for testing like stated by mtber 2 good things take off the vaklve cover and if you have time take off oil pan i have a engine stand to bring also have volt meter to check sensors
i love AUTOZONE
Old Mar 13, 2005 | 10:49 AM
Jake's Avatar
dýsfuňctiønal
Ill be leaving Monday around 6-6:30pm. If you can go, that would be great. You seem to know alot about motors and whatnot, so any help is better than none.
FLeuro
TheCommision
Old Mar 13, 2005 | 12:24 PM
Jake's Avatar
dýsfuňctiønal
poop
FLeuro
TheCommision
Old Mar 13, 2005 | 07:37 PM
  #18 (permalink)
seanpoe's Avatar
n00b
someone help him out
AIM - sPeOaEn
Old Mar 13, 2005 | 08:16 PM
  #19 (permalink)
mtber's Avatar
Checking sensors would be a useless waste of time.
Map, tps sensors etc, rarely go bad. As long as they are in good physical condition they should operate properly.
Old Mar 13, 2005 | 08:38 PM
  #20 (permalink)
RoninB18C5's Avatar
Eh, I'm tired of Hondas
Nothing's a waste of time... Better safe then sorry.... One less thing to worry about...
