Need help adjusting camber...
Old Mar 8, 2005 | 08:29 PM
Jake's Avatar
dýsfuňctiønal
Any idea how much something like this would cost?
FLeuro
TheCommision
Old Mar 8, 2005 | 08:33 PM
Cosmo Rockit's Avatar
Urdaddi
I already had front and rear camber kits installed when I took my Si in for alignment and camber adjustment. I discussed this with them (doing the whole job using washers, etc instead of camber kits). I believe they said something like $240 total including the alignment. And this was line within the last month I talked to them so that's current pricing.
That's pretty cheap y friend....way cheaper than camber kits....heck the alignment and camber adjust cost me $80 alone. Get 'er done!
Old Mar 8, 2005 | 08:37 PM
Tits McGee's Avatar
is cooler than you
If you have less than like 1.5 degrees, just leave it, and make sure you rotate regularly.
Or like everyone else said, use the Home Depot $0.48 camber kit.
Old Mar 8, 2005 | 08:47 PM
Jake's Avatar
dýsfuňctiønal
I dunno if you caught it or not, but i have a ingalls camber kit in the rear. Its not off by much at all, i just dont want my tires to be camberd at all.
FLeuro
TheCommision
Old Mar 8, 2005 | 09:06 PM
Urdaddi
yup...and you WILL get camber wear, trust me. that's why I had the Chavez fellows install the Skunk 2 kit up front and the Specialty Products for the rear BEFORE we put the g-Force KDW's on.
Old Mar 9, 2005 | 03:56 AM
osama tim laden's Avatar
kings cannot fall.
you can adjust it yourself, but changing the camber will change the toe settings, and toe will wear out a tire way faster than camber.
just take it to tire kingdom, or any alignment shop, and make sure you tell them it has camber kits.
the person that paid 240$ for an alignment got extremely ripped off.
Old Mar 9, 2005 | 04:52 AM
  #17 (permalink)
Tits McGee's Avatar
is cooler than you
You know camber kits have a tendancy to make noise, right? That in itself would make me return the Ingrals kit and do the Home Depot fix.
Old Mar 9, 2005 | 09:09 AM
  #18 (permalink)
kings cannot fall.
how could a camber kit possibly make noise?
seriously.
Old Mar 9, 2005 | 10:17 PM
  #19 (permalink)
civicsi2g813's Avatar
TR Balla Donor Supreme
if we are talking about the rear there is no noise involved.......... the ing front camber kit has been known to hit if your car is 2 low but the rear kit is a ok..........also the home depot trick has nothing on the ing kit.......although the home depot is cheap it doesnt give as much of an adjustmant
drinkin hatorade since 1980
Old Mar 10, 2005 | 02:37 AM
  #20 (permalink)
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
Originally Posted by Cronic
+eleventy trillion
idk about all that,but you are right about taking it somewhere.I did my own when i did my front and rear camber kit,and so did one of my friends,both of our alignments are perfect,but then again we both held the wheels straight while our fathers fucked around with whatever,but yeah.Ive heard the washer trick works well and is a low cost mod,ive never done it but i have a few friends who have.
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
Largo
Nissan/Infiniti Tech
6
Feb 2, 2004 08:07 AM
Chin
9
Dec 10, 2003 04:18 PM
Hybrid93Hatch
Jul 30, 2003 08:04 AM
Drop Them N1kes
Mar 31, 2003 08:10 PM
