Question about Camber Kit
Old Mar 29, 2003 | 08:14 AM
Drop Them N1kes's Avatar
+Tien sus
Default Question about Camber Kit
Last Sat. Jesse informed me that my right front tire had some bad camber (positive). I was going to get a camber kit long before this, but i realized that I didnt know how one worked....can anyone explain how this thing corrects camber? Thanks
Mr. Game and Watch Drift
Old Mar 31, 2003 | 07:27 PM
Echo7847's Avatar
A camber kit is actually a pretty easy thing to understand.
For the rear, some people use washers as a cheap way of adjusting it, or you can buy a camber kit from Ingalls, spc, etc. It looks like this
You can adjust it so that it pushes the top of the wheel out further(positive camber) or so that it tucks the wheel towards the inside (negative camber). Works the same way for the front but looks different. Pretty much the same principle, pushing out or pulling in to set the desired amount of camber on the vehicle.
Understand?
Old Mar 31, 2003 | 08:10 PM
delsolSI's Avatar
basically...it makes your wheels parallel and will save you a lot of money in tires, cause when you camber is bad, over a long period of time your tires will rub down....
-2003 Ford Mustang
-1986 Toyota Corolla GT-S
-1993 Honda DelSol Si
Toys:
-2003 Honda cr125r
-2003 Honda cr250r
