Need help/info/pics of Scatter Shield install/installed
Old Mar 4, 2005 | 07:44 PM
Punkinterviews's Avatar
Chavez Motorsports
Default Need help/info/pics of Scatter Shield install/installed
Here is a pic of a GE Scatter Shield......the one I received has 2 mounting points on it and not 3 like pictured. It was purchased for a Hydro GSR does anyone know if this is correct or is the last piece missing? Also any info on install on Pictures would be great!!! The one point I'm missing the the one in the upper left corner by where the stater would go.
Thanks,
Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Mar 4, 2005 | 08:07 PM
mtber's Avatar
Just by looking at it, it looks like it bolts onto 3 17mm tranny bolts...
Old Mar 4, 2005 | 08:10 PM
Chavez Motorsports
Yeah but the jackasses didnt include the last piece!!! Also I tried to line it up with the tranny and I'm lost!!! BTW tranny is out of the car and I have a block sitting next to it so I'm totally clueless.
Kris
Chavez Motorsports
Old Mar 4, 2005 | 08:14 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
the bottom bolt goes through the block i believe, then the one in the top right of the pic goes on the tranny, and you NEED to get that other mount from GE....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Mar 4, 2005 | 08:15 PM
mtber's Avatar
Im pretty sure you have to have the block mated to the tranny in order to install it...
If you look at the bottom mount bracket, it looks like it does on the rear lower 17mm tranny bolt...
Old Mar 4, 2005 | 08:43 PM
qitstrn's Avatar
Can you spot me 20 cars?
mine is out or i would show you a pic
Old Mar 4, 2005 | 09:08 PM
Retired Ricer...
Kris, I will come over and install it if you give me a discount on the block guard
Old Mar 4, 2005 | 09:45 PM
60-1EK's Avatar
Engineer at the source
Put the tranny in first, then put it on. Do I need to take a pic of mine to show you. Plus you are missing the back piece. Camp sucks man.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Mar 5, 2005 | 03:01 AM
Retired Ricer...
Camp, as in, Camp1320?????
Old Mar 5, 2005 | 04:40 AM
NChatch's Avatar
i stepped on my weiner!
yeah you need to have the spline just sitting inside the clutch to install all of this, although you should be able to placeit up next to the block and get an idea of where it goes. and yeah you need all of the tabs that hook to the allen bolts for it to work or be installed properly, if yo have it, THEY will look at it, just like a rollcage, they will look at it, and inspect it. so call good ole' camp 13million and tell them you want your shit!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
