Stripped Tensioner Bolt
Old Mar 4, 2005 | 03:00 PM
BitbyStreetRacin's Avatar
once your bit, your done.
Default Stripped Tensioner Bolt
Im really frustrated on this situation and need some input on some techniques on how to get stripped timing belt tensioner bolts out. I do not want to take my motor back out of the car so I have an angle drill bit and tried to drill a small hole so I could get my backing-out bits in there. Had the hole in the bolt, just about ready to put the backout bit in, when the drill bit breaks inside the bolt. With my luck, of course its a carbide bit so its going to be a bitch to drill it out now. Should I keep going with this method or do you guys reccommend something else?
Old Mar 4, 2005 | 03:06 PM
mtber's Avatar
Remove the side plastics.... (Timing belt)
Use a grip lock style tool to grab the bolt....
If that doesnt work, take a dremel to it, then use a locking tool to grab the bolt and take it out
Good Luck.
Old Mar 4, 2005 | 04:23 PM
By dremeling you mean making it flatter on a couple sides for the locking tool to grab?
Old Mar 4, 2005 | 04:34 PM
mtber's Avatar
That or, completely cutting the head of the bolt off so that you can use a tool on the remaining stud...
NChatch
Mar 24, 2004 04:04 PM
superdave
Feb 10, 2004 10:53 AM
mike34655
Power Adders
9
Jan 26, 2004 01:02 PM
gotvtec20
Jan 1, 2004 07:42 AM
Legato
Apr 18, 2003 09:42 AM
