well my turbo ish came in..woot
well my stuff finally came in for me, im happy with it all, all i need it some needed i/c piping, a down pipe, bigger fuel pump and a chiped ecu and some other misc. crap....its gonna be one fun project...
..looking at about 195whp at 8-9psi with my current stock motor after i change a few things before i put it on as the headgasket and such....nothing to drastic, while im doing a turbo build on another motor.
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
the whole thing is for my accord, i'll be running the 14b (small i know), its the whole DSM setup...needs a little clean up, but the whole thing its self is in great condition.
i dont know if 8-9 psi is going to be sufficient enough to make 195 whp, maybe 180ish. but hey, hopefully you get the numbers your after. what size injectors and engine management you using?
well there are welds on there, when i asked the guy about that, he said they had reinforced it to prevent it from cracking, so hopefully he didint BS me...im running 450cc's injectors, 255 fuel pump and ill be running a chiped ecu, i may run a SAFC, but i dont know..after my build is completly done(f22a6 build), im looking for the 220whp+ range...been trying to get it all pieced together for about a year now.
195 is a number that is a little out of reach on how its all pieced together now, but its been done, on a bare stock motor, no moddifications to it, or replacement of anyparts...so its something to shoot for, so i hope i can produce anywhere near there would be good.
that wastegate is set at 10psi. you cant boost less than 10psi. that should be fine with a decent tune. I would run uberdata or crome. also a wideband is a MUST, unless your going to have someone tune it the second it is installed.
Underground Performance
Power Adders
Sep 24, 2002 10:36 AM
