Blurbo B16???
Originally Posted by LuckyH
I have priced some internals and am thinking of going blurbo for a project car. It's getting to be that time where i am ready to buy some parts for the motor. I have priced out some new Eagle rods for $380, SRP 9:1 pistons for $445. Assuming im only wanting in the 350hp range, would the stock crank be strong enough? Also, i've been told that i should just use the stock rod/main bearings from Honda. I will also be using a block gaurd. The motor will not be bored, only honed and hot tanked. I afraid if I make the cylinder walls any thinner i would have to have it re-sleeved, which im trying to avoid. Well enough rambling, would this setup be on the safe side, im looking to overbuild this motor for what hp i am wanting to run.
Originally Posted by qitstrn
Never had a problem with mine or the other 5 motors that i have built with them.
Also the price i got on the rods included ARP rod bolts. And the price of the pistons didn't include rings, those are $99 for the set.
SickofAlltezzas-
DAMN, I can get you a complete set of CP Pistons for less than the SRP's!!! And these are more trusted!
Kris
Kris
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
hrrmm.... <--- Never had a problem w/ srp's. Cp's working fine too. Shouldnt matter if your shooting for 350. Good Luck!
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
I ran SRP pistons in my last motor and they held up just fine... They survived a hell of alot of detonation, and numerous top end runs where everything tends to heat up much more than normal...
I did however go with CPs for my new build just because they are suppose to be a better product, and I got a hell of a deal on them....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
$775 with H-beams shipped?
Chavez Motorsports
Chavez Motorsports
