Project: F/i Killer
Old Mar 2, 2005 | 02:36 AM
  #21 (permalink)
na200whp's Avatar
Powered by BOOST
some info--
block was done by golden eagle. 1/2inch deck plate
(they do not weild on there plates instead they use some kinda compound between the block and plate and bolt them together.)
bore is 84.5mm with weisco/endyn pistons
crank eagle 95mm stroker crank with eagle 5.967" rods
the displacement of this block will be around 2.13 liter
i am currently have the w/p block off plate w/ electric pump but may go back to an oem pump before it makes it to the car.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
Old Mar 2, 2005 | 04:37 AM
  #22 (permalink)
The Spectacle's Avatar
Spent more money than you
nice.
Racing Integration
LHT Performance
My tuner is named Alpha
Old Mar 2, 2005 | 05:45 AM
  #23 (permalink)
qitstrn's Avatar
Can you spot me 20 cars?
Originally Posted by na200whp
some info--
Looks great. I dont know what compression you are running but a vacumn pump will work great to relieve some of the crankcase pressure. I cant wait to see you embarass some of the turbo guys. Luckily for me i dont have to worry. Good luck with the rest of the build.
Old Mar 2, 2005 | 06:27 AM
  #24 (permalink)
PantySniffer's Avatar
grippin grain
Nice......N/A is best bitches....That is some dome on those pistons....Mine are 12.5:1 and yours look way taller. This motor is goin into an eg? What head and cams will you be using?
Obsession is a word used by the lazy to describe the dedicated.
GO GATORS
Old Mar 2, 2005 | 06:33 AM
  #25 (permalink)
NChatch's Avatar
i stepped on my weiner!
NA200whp is like the poster child for NA motors!
if its NA hes all over it, his head is top notch and as far as cams, i think hes dyno'd everything on the market to find the right combo of parts, trust me it will be worth seeing the dyno sheet after hes done!
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Mar 2, 2005 | 06:53 AM
  #26 (permalink)
BigBodySmith's Avatar
Retired Street Racer
You are the man, what cams you using?? ITBs??? might want to change your name to na240whp!!!
Also, what tranny you using?? is this still going to be street driven???
My Old Honda
Old Mar 2, 2005 | 06:54 AM
  #27 (permalink)
juiced2ndgenteg's Avatar
nice deck plate. thats the first I've seen being used on TR. much props to you.
Old Mar 2, 2005 | 07:46 AM
  #28 (permalink)
qitstrn's Avatar
Cory's had his done for 2 years now. Unfortunately he has a big mouth and got banned from TR so he doesnt post. I cant reveal his setup but it runs 11.30's on the motor. I'm glad to see someone else building a serious allmotor car.
Old Mar 2, 2005 | 07:47 AM
  #29 (permalink)
qitstrn's Avatar
some info--
BTW is this going to run on pumpgas?
Old Mar 2, 2005 | 07:54 AM
  #30 (permalink)
Punkinterviews's Avatar
Chavez Motorsports
Yeah, it'll pump right from the C16 tank into his
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
