Which ignition on 425+whp SOHC Vtec Turbo?
Old Feb 28, 2005 | 01:56 PM
boostedb16a3's Avatar
Equal Opportunity Hater
Default Which ignition on 425+whp SOHC Vtec Turbo?
The goal is to have at least 450whp but we will see what happens when its on the dyno. Now my question is what ignition setup do you guys recommend? I've heard msd 6 plus, 6AL, SCI, etc. How about the external coil? Blaster 3 coil or something bigger or different?
LMK what you guys think.
-boostedb16a3
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Originally Posted by JAVIELITO
limpio as fukk
Old Feb 28, 2005 | 02:36 PM
qitstrn's Avatar
Can you spot me 20 cars?
-boostedb16a3
I would run a 7al over the 6 because its better. If you really want a nice ignition they make the 7al in digital but it's twice the price.I run the HVC2 coil by MSD and it's one of the best coils that you can still use on the street.
Old Feb 28, 2005 | 03:08 PM
Gotin's Avatar
Sayien
I have used MSD 6al, it kind of improved revving, but i think that the stock ignition is the best for hondas.
-B.J.F-
Old Feb 28, 2005 | 03:53 PM
60-1EK's Avatar
Engineer at the source
Stock. I made 600 with a stock honda ignition setup and there are tons of other people out there as well who are making 500 + with stock honda ignition setup.
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 28, 2005 | 03:56 PM
Hybrid_eg's Avatar
i like the blue ones
I'm going to have to agree with Gotin on this. Erik Aguilar's 9 second all motor monster utilizes the Honda factory ignition and revs to 10,000 RPMs. Maybe PM Trip about his 300+ horse turbo SOHC VTEC and ask about ignition. Maybe he can lend you some insight.
Shut yo ass up nugguh..
ReginaVagina
Old Feb 28, 2005 | 05:01 PM
Trip's Avatar
Dramatic Lemur
OEM gets my vote. Not knocking the aftermarket ignitions, they have some perks But, IMO, they are a luxury item and the money could be better spent elsewhere. And with an SOHC, you just want to get to the point because most likely the build is budget oriented. Probably always a good idea to keep up with a good working distibutor and well kept plugs. Depending on the milage of your motor, new OEM wires might do some good. I need to take my own advice
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
Old Feb 28, 2005 | 05:56 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
The only reason I went aftermarket was to have the use of a 2 step rev limiter that I can change at my own free will
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Feb 28, 2005 | 07:36 PM
EludeR's Avatar
OEM is sufficient. Don't see why it would be needed to be replaced with a aftermarket setup.
Old Feb 28, 2005 | 08:21 PM
NChatch's Avatar
i stepped on my weiner!
stock, but i use MSD for the 2 step because it cuts spark and not fuel
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Mar 1, 2005 | 12:34 PM
chet's Avatar
All Aboard
Most people have issues with their stock ignition when its old and worn out. As 60-1ek stated, stock ignition is awesome and works perfectly with 500-600whp.
