Which ignition on 425+whp SOHC Vtec Turbo?
Thanks for the swift responses guys...
The vehicle in question is a 91 civic dx. I purchased it as a shell and all wiring was intact, and had 125k on the clock. I usually here people say stock ignition on their newer vehicles. For example Trip, and probably 60-1Ek as well as the rest of you. The motor is fully rebuilt, and capable of handling upwards of 20psi. This is a SOHC Vtec. Im just trying to see if I will need the added spark or not. Of course I want the cost effective route, but I want to have what I need to get the most out of my setup. I hope that is understandable. I found a guy selling a MSD SCI for 125, for just the box but I would still need a coil, wires, and a cap. Or maybe I could just use a blaster 2 or 3 coil with a msd cap? any further insight?
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
STOCK. Get some stock NGK wires, some 7 series plugs and a new cap/rotor.
I agree with these guys...but if you really want the aftermarket ignition for the st00pid cheap, I'll sell you the MSD shit off my car for $50. I don't know what it is or what it does, but it clutters up my engine bay and I don't want it
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
thanks again for all the swift replies.
+100000000
and for a 2 step rev limiter, if your wanting it for drag so that you have a launch rev limit and then the top end limit............HONDATA......... and you can change it at the push of a button, or key stroke if you hook it up to a laptop. hondata also has the full throttle shift, I haven't used it myself but hell it's hondata, you can't go wrong. I am not sure if it's ignition cut is fuel or spark but 60-1EK probably could.
I had the blaster coil on mine and when I'd drive around 5krpms for more than a mile it would start to hesitate unless I went to 6k or 4k and the only way to make it stop was to drive for a while at a different rpm, I know big deal.....but in 5th gear on the hwy 5k put me at 70-78mph so slower sucks and faster is a ticket. I took of the blaster ss coil and went back to a stock ignition, it's been a year and no problems. I am currently working on a build for my b16 to run 20-30 psi and the only thing I will do to the coil is replace it (100k miles approx) with a brand new OEM coil.
