Help!
Old Feb 27, 2005 | 05:23 AM
JDMCRXSOHC's Avatar
Exclamation Help!
Aright i was driving the rex this morning and i was coastin about 40-45ish in 3rd... Then Out of nowhere the car shuts off.... I can't pull the car out of 3rd either. it's Like someone has holding it back from moving ANYWHERE. So I ended up coasting the car to a near-by street. I start the car up but then Still can't move the stick out of 3rd. So i tried juss trying to see if the car will start off in 3rd. NOPE sounds like it's struggling and then DIES. Car doesn't move Period. It So happend my parents were passing by so they went behind me and pushed the car.. I tried to slip the clutch to see if it would catch but nothing. The tach moved up to where the proper RPM and MPH would be nothing. The Stick itself was SUPER hard to move around. All Gears were like this....So i parked it at my Cuz house cause i was close to it. Now... Could this Be my Tranny? Axles? Shift Linkage? Clutch?
Info on the Car: 1990 CRX Si With the Stock D16A6 and Tranny.
Old Feb 27, 2005 | 10:08 AM
ekhatchboy's Avatar
Redrocket part 2
check the fluids?
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old Feb 27, 2005 | 04:39 PM
JDMCRXSOHC's Avatar
Nope Not the Fuilds....
Whe i "have it in gear" and try to move the car doesn't move but the TACH reads that i'm moving.
But the Stick is Still Way to Hard to Move.
Old Feb 27, 2005 | 05:11 PM
iskate2's Avatar
wears black
sounds like a throw-out bearing, mabey? im not an expert in this area (yet), but it seems like why you cant pull it out of gear.
Quote; Stan Marsh from "Southpark", concerning his friends Cartman, Kyle, and Kenny obsessing over facebook:
"You guys are retarded, I'm playing XBOX."
Old Feb 27, 2005 | 06:16 PM
alri0085's Avatar
Scuderia ALRI
I don't think it's the throw out bearing. If you can shift gears but the car doesn't move it's the clutch or throw out bearing. In your case you can't shift gears, so it looks like the tranny is gone, but check the shift linkage just to make sure.
Old Feb 28, 2005 | 04:04 AM
JDMCRXSOHC's Avatar
Thanx i'll check those out...
Thing is.. i can't even tell when trying to put it into another gear if it's in GEAR. I'll Check the Linkage.
How much does a throw-out bearing cost? Is it hard to Replace? Located where?
