Cr/vtec ???
i havent been hiding anywhere, you've been hiding
i have been here at my house, you know where i live. i bet if you had a fully built motor that could rev to 10K and make power all the way up there it would see 2500 its whole life
i dont know how many of these guys have built / run b20 vtecs but ive owned one for 2 years . stock sleeves are not that week. poor/no tuning and high crankcase psi kill b20 blocks most of the time. if done right they can and will last . my block is even .5mm over bored so the sleeves are even thiner and she is still ticking . i rev my motor to 8500 and this is on 12.8 to 1 compression. im sure some will say im lucky but i know other wise.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
Originally Posted by LuckyH
I think it matters on which B20 you get. I thought the stock B20z had 9.5/1 compression with a redline of 6800. And isn't there a B20b which has lower compression, like 8.5/1 and a redline of 6200. I wonder what's the difference in volume between the stock B20 head and the B16 head as far as raising/lowering compression just from switching heads. I wouldn't mind having to install some aftermarket rod bolts if it meant a lot more reliability, the motors probably only going to see aboe 7200rpms a couple times a month. It just seems like a waste of money to spend $1500 to have a stock motor.
Originally Posted by mtber
Building a n/a motor with less then 11.0:1 c/r is a waste of time.
very tru bro, compression wont be all that great by just slapping on a vtec head, will it work okay...yes, will it yeild massive power....no but it will give you some torque. i think its great as just a replacement motor for messing around with.
the vtec head was designed to scream, and the B20 was NOT, in stock form.
also like NA200whp said, PROPER tuning owns most people
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
