Brake setup
Old Feb 17, 2005 | 07:07 AM
94lsteg's Avatar
BOOST IS BETTER!
Default Brake setup
What is a good cheap** big brake setup for a 94+ teg?
Old Feb 17, 2005 | 07:32 AM
mtber's Avatar
Discount rotors with aem pads or any aftermarket pads such as axxiss etc...
Old Feb 17, 2005 | 10:52 AM
NChatch's Avatar
i stepped on my weiner!
i dont have a "big brake kit"
but i did use power slot rotors, and now i have HAWK pads and thye bite and stop like a bitch.
i HAVE used AEM pads and were super impressed at the way they had almost no brake fade at all.
i dont recommend any real big brakes because unless you change the master cylinder too, then your stock one will still be trying to clamp its calipers with enough power to stop small brakes, not large ones.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Feb 17, 2005 | 10:57 AM
60-1EK's Avatar
Engineer at the source
Good and cheap don't go in the same sentance. Why are you wanting a big break setup for your car? what lines are you running? What pads?
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Feb 17, 2005 | 05:38 PM
NSXtacy's Avatar
Go Fast Crack Pipe
+1 Jason, hi by the way.
My friend has a set up for race Civics which nobody can touch his braking ability. He owns Cobalt Friction down south, but it is pricey for the street. An alternative I will have availible in a few weeks, drilled/slotted OE size rotors that have been cryogenic treated matched with Cobalts pads. Good looks, good braking, increased durability for a fair price.
PM me for details.
"It's OK to Smoke V-8's" - Surgeon General
www.2NRWerks.com - NSX, S2000 & RSX specialist. AEM, Hondata Kpro & Crome tuning provider. Custom built F, K & B series motors. Custom "Safe" Nitrous Kits and NOS Refills (While-U-Wait). Suspension/Brake Specialists & Alignments for lowered cars. On the quest for 700whp S2000 roaming the streets early Spring.
To Schedule An Appointment Call: (813) 876-VTEC
<< Reputations are so overrated! Don't hate on me 'cause I build fast cars.
Old Feb 17, 2005 | 06:45 PM
NChatch's Avatar
we should have asked............leave it an NSX owner to tell us about brakes, they should know, they have the heavenly brakes oin those beasts!
i SCCA'd my car for a year and love my little brake pad/rotor set up, worked great for me and i use it in drag racing today still.
owner/operator
Old Feb 17, 2005 | 07:59 PM
sxecrow's Avatar
EG2 CRX
so just slotted factory size rotors with Axxis pads will work?
-94lsteg
Old Feb 17, 2005 | 08:11 PM
NChatch's Avatar
will work fine, i recommend, brake lines as well, because the brake fluid sits in there for so long it just ruins the inside, ever notice brake fluid is one color when it goes in but different when you bleed it coming out??
when you do em, bleed all of them and try to get the funkiness out. if you can go to amazon hose in tampa just measure your brake lines, tell them the fittin sizes and they can make lines for like 15 buc a piece..........just dont tell them they are brake lines, they aint supposed to make em. tell them they are clucth "hard line" replacements!!!!!
owner/operator
Old Feb 17, 2005 | 08:54 PM
KJ's Avatar
KJ
bored at work
Also run a good brake fluid and flush all the old fluid out. AS brake fluid gets old it absorbs water and brings its boiling point down.
Old Feb 18, 2005 | 04:28 AM
NChatch's Avatar
excellnt point KJ, i used the high temp motul fluid.
after i boiled my brakes @ sebring like 10 times in an afternoon.
owner/operator
