Engine Diagnosis
Old Feb 15, 2005 | 09:25 PM
lead's Avatar
I'm Awesome
i replaced the valve cover gasket a short while ago i just replaced the cam cap with the srt one and i will pcik up the vtec gaskets tomorrow, i will then scrub that dirty bitch down and see if it leaks again,
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Feb 16, 2005 | 01:41 AM
Stephan's Avatar
Originally Posted by KJ
Replace your valve cover gasket, distributor o-ring,vtec solenoid gasket and cam plug seal and your oil leaks will be gone. I've been working on Honda's and b-series engines in particular for a long time and I've never came across a head gasket that leaks oil without being the direct result of a bad mill job or a poorly done vtec plug in an lsvtec.
Replace your radiator and get a block check kit to determine if there is coolant in the combustion chamber.
listen to this man he knows his shit
DSM Part Out
Old Feb 17, 2005 | 12:40 PM
lead's Avatar
I'm Awesome
replaced those seals, still light leakage by by head gasket, but i have a broken manifold stud and while i was adjusting my valves i noticed that my timing is advanced by one degree on the intake side, so since the engine has been toyed with maybe the previous owner changed out the gasket before. anyway i have pic's i'll post or have them posted for me later tonight.
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Old Feb 17, 2005 | 01:01 PM
sxecrow's Avatar
EG2 CRX
My lovers pics
UrbanFuturistic
Nov 11, 2003 04:48 PM
Cronic
Oct 10, 2003 07:20 AM
Scott
Jan 2, 2003 10:14 PM
81linkin-R
Toyota/Lexus Tech
Dec 4, 2002 06:07 PM
