Draining the Block
Old Feb 9, 2005 | 05:00 PM
preludepimpin's Avatar
Question Draining the Block
does anybody know how i can drain out the antifreeze in my block...its a f22b engine and i gotta figure out a way to drain it out...thanks!
~!~LG State Champs 2002~!~
Old Feb 9, 2005 | 05:25 PM
NChatch's Avatar
i stepped on my weiner!
yeah pull the plug on the bottom of the radiator............... and let it all pour out!
there is a plug which looks like a uhge bolt on the back of the block, take that out if you have to but i dont recommend it.
why you trying to drain all the fluid out with the block int he car ????
Old Feb 9, 2005 | 05:40 PM
i was changing out my head gasket and got stuff all in the antifreeze
Old Feb 9, 2005 | 05:45 PM
crazyhatch's Avatar
someone's been in here b4
the lowest place on the block to drain the block is above the the deck just fill it up and run it for a few then drain it again or leave the hoses off and run it with a water hose in the upper hose and the lower running out on the ground
Old Feb 10, 2005 | 02:25 AM
Trip's Avatar
Dramatic Lemur
Definately just run a hose. Take out the thermo and just let it run a while. That's how it's done. Or, if you got $$, take it to a place that can do a pressure flush on the entire system, radiator included. Should only be around $40.
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
Scott
Dec 24, 2002 08:58 AM
