Bad News (turbo issue)
Apparently doug's (94lsteg) turbo is not running correctly...again. He just called and said that he is showing boost but it's not going anywhere. He is on his way over so we can check for shaft play.
Kinda sucks mainly because he doesn't really dog this snail out at all. And secondly because almost everything that could go wrong with a car does go wrong with his...
This post might be premature but any ideas as to what the problem might be?
He says its not a vac leak or a boost leak so we will shortly find out :\
prob another trip to visit good ole' dave is in order.
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Guest
Posts: n/a
Making boost, but no power? Could be the turbo... might not be. Make sure the wheels have not made contact with the housings. If they have, it's time for a not-so-cheap upgrade.
do NOT run a turbo that has touched the housings. This WILL grenade eventually. Boom no good.
Guest
Posts: n/a
-Keith
Guest
Posts: n/a
They wont lock to the housing right away, the might not ever lock up.
I've seen turbos that made 20+psi and made shitty power. It had a lot of play but wasn't hitting the housing yet.
2 weeks later, it began to hit the housing.
I told the guy it needed a rebuild soon, but he just wanted to run it till it blew up.
The car would make boost and go nowhere... then make no boost and also.. go nowhere.
He trashed the compressor wheels the bearings, the housings and basicly. The rebuild was over 700 dollars.
If you keep running a turbo that is touching the housings it will die a horrific and exciting death.
Actually. Keep doing it, and take pix when it goes.
Guest
Posts: n/a
I don't know anything about this kid's setup either. If his boost source is comming from the wastegate it could show boost, and he could have a blown IC pipe.
The fact that he shows boost, and isn't going anywhere is a not so great sign. Only two things I can think of are the turbo and the motor.
Guest
Posts: n/a
-Keith
Guest
Posts: n/a
Originally posted by `92CXhatch
you run a boost gauge after the T-Body... like on the intake...
not off the WG...
-Keith
-Keith
it also could be because he has no clutch, so.... thus he is making boost but going nowhere.... as in his motor is putting down no power.
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
KJ built
ALPHA TUNED
THANK YOU!!!!!!!!!!!!!!!
If the turbo was bad, it wouldnt show boost at a post throttle body source.... If there is boost in the intake manifold, it is getting to the motor... Either the clutch is finally 100% toast, or the motor went to the pooper....
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
update: he gets it pulls when he is at full boost ... but when he is at lower psi it doesn't pull at all aka like na engine
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
