Changing Axles
Old Feb 1, 2005 | 07:19 PM
SleepingB18's Avatar
just mike.
Default Changing Axles
Last Sat. I changed my axles and fixed my camber kit, and tonight i hear something as if its a sticky paper stuck to the tire. I pull over to feel if there is a sticker and.... Where the fuck did the tread go???? I felt a thin rubber tire. And its starting to do it on the passenger side as well. so my question is, by changing axles, does it screw up your "toe" at all? ( I had to take off the steer rods to get the sprindle out) i have a adjustable camber kit, and I adjusted it all the way towards me. is that correct ? this shit is just falling apart on me..............help
Old Feb 1, 2005 | 08:19 PM
smoke3's Avatar
Its a secret
re adjust ur camber kit.
if my mental picture is correct all the way out toward u mean the outer edges would be worn
whst tire stance do u have / / \ \ or \ \ / /
u cant have the camber kit all the way in one direction and expect it to work right.
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
Old Feb 1, 2005 | 08:26 PM
rebels's Avatar
Shaved Accord
just like smoke3 said, adjust the camber kit. when you're messing with the axles you're going to need to readjust it anyways just like putting a new suspension set on.
most likely it's the wheels sitting like // \\ cuz having them inward would throw off your steering and balance of the car wayy too much to be driving daily.
Adam
University of South Florida - Graduate School
Old Feb 2, 2005 | 03:24 AM
DOHC16CRX's Avatar
CARPET GUY
its your toe..when you change your camber it throws it all out of wack..you must get your alignment dont..
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Feb 2, 2005 | 05:19 PM
just mike.
I took it to my friends at Ace and they said it was when i changed the axles, also when I installed the springs and shocks I must had turned the spring out of its place while trying to get that bolt pushed through the controll arm somehow. It rides alot better now......me so happy
