lug stem help asap PLEASE
Old Feb 1, 2005 | 02:45 AM
travis21's Avatar
Default lug stem help asap PLEASE
:bbb: i'm tryin to replace the lug stems on a 2002 honda civic ex i have the wheel, the caliper, the rotor, the axle nut all off. but can not remove the lug stems i could not find a notch or any way to get them out. any help or suggestions would be greatly appreciated.
PLEASE HELP
Old Feb 1, 2005 | 03:47 AM
lead's Avatar
I'm Awesome
....umm hit them with a hammer they are pressed in.
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Feb 1, 2005 | 04:01 AM
travis21's Avatar
right i did, it doesn't have clearence to just get hit out. the big metal thing that holds the strut is right be hind it there is no way out. i have to find a way to either get that knuckle off any ideas or maybe ways to get the lug stem out.?????
Old Feb 1, 2005 | 04:09 AM
Punkinterviews's Avatar
Chavez Motorsports
Dont you have to depress the wheel bearing and get them out/in that way then repress it?
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Feb 1, 2005 | 05:06 AM
travis21's Avatar
no idea sounds like it would work how do i do that do i need a tool.
thanks for your help
Old Feb 1, 2005 | 08:55 AM
TSX24L's Avatar
looks like somebody has the case of the helms.
Old Feb 1, 2005 | 09:05 AM
05 TypeS DC5's Avatar
07 e92
+1 on that Kris
I've had this happen to me 2 times on the driver side. You can use the FATTEST hammer ever, your not going to get it out unless u press out the wheel bearing. What i would recomend doing is taking your control arm off, which is reall easy takes like 10 minutes... and drop it off at a machine shop, if you live in town and country u are in luck, on waters ave theres a machine shop attached to Advance Auto parts on Hanley.... They press it out for you for 50 bux and you might as well replace em all w/ brand new ones which cost around $1 each... Trust me you will save ur self the pain later... No matter how easy anyone will make it sound its not that easy, you actually need a machine to press the wheel bearing back...
Old Feb 1, 2005 | 09:38 AM
lead's Avatar
I'm Awesome
on the del sol we don't have the knuckle in the way.. del sols rock, anyway since your car sucks you need to use a wheel puller, doesn't take long since you have all the stuff already undone just undo axle bolt and use wheel puller to pull it off then hammer them out and blah blah blah it's not difficult
EDIT: 50 bucks! screw that spend 15-25 on the wheel puller
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
Old Feb 1, 2005 | 10:20 AM
Chavez Motorsports
Since your replacing them, might as well go with either ARP or SKunk2's while your at it. That are alot less likly to spin like OEM ones are!
And personally if you pull it I'd take it to a machine shop and let them do it and replace the wheel bearings while it's apart....but thats just me.
Kris
Chavez Motorsports
Old Feb 1, 2005 | 10:31 AM
lead's Avatar
I'm Awesome
not to be conflictive but its an 02....mine is a 94 and finally just one of the bearings is starting to go out.... not even there yet. and why change out to high performance, the normal ones work fine
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
