Slipping out of 5th
Using The Force Of N/A
on
Slipping out of 5th
Wow now I have another thing to add to my long list of shit going wrong. I just had a new clutch put in less than a month ago with my rebuilt motor and now the car is slipping out of 5th. I can shift into 5th with no problem and I'll be cruising along for 2-4 miles and for no reason it slips out of 5th and into neutral. Is this a bad alignment on the clutch/pressureplate/flywheel or what?
well i would recommend spending 30 dollars on some es engine torque mounts if there is a possibility of it being bad mounts....if not look into a rebuild. neal does it pretty cheap.
that may be where i am heading as something is wrong with my clutch / tranny
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
its your syncro's bro,i have had that problem with 2 cars i have had..it would just pop out of gear..
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Guest
Posts: n/a
ding ding ding!!! you get the prize... this is the correct answer... BUT, something to try is try putting some GM syncro mesh in there and see how she runs... you might be surprised how much that shit can do for a tranny...
-Keith
if none of your gears are griding then your really low on MTF..
get some honda MTF in there and see if that solves your problem
check for a leak somewhere also, around the axle seal most likely
