93 civic ex: starting hard when cold
Old Jan 6, 2005 | 09:05 PM
boostedb16a3's Avatar
Equal Opportunity Hater
Default 93 civic ex: starting hard when cold
Its all stock. All servicing has been done except valve adjustment. 97k miles. I've owned the car for about 10k miles and always use 93 octane. What the hell is going on. It just starting doing this about 300 miles ago if that. First it sounded as a very slight squeal in the belts but now it just starts hard like.
any suggestions. Haven't had a chance to really trouble shoot but I have a had enough time to dick around the net so thanks reading.
-Joe
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Originally Posted by JAVIELITO
limpio as fukk
Old Jan 7, 2005 | 08:40 PM
limpio as fukk
Old Jan 7, 2005 | 09:16 PM
lead's Avatar
I'm Awesome
..if the belts squeal they are loose tighten them
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Old Jan 7, 2005 | 10:10 PM
mtber's Avatar
What do you meen by a hard start ?
Has the fuel filter ever been replaced ?
Old Jan 8, 2005 | 04:30 AM
yes the filter has been replaced. It has received a full srvc. all belts, water pump, hoses, cap, rotor, oil pan gasket, axles, you name it and it has been changed.
starting cold meaning it seems to rev a bit higher on the initial start up and the transition of it turning over to actually being started is hard at times. I just did an oil change to mobil 10-30w and it seems to be ok. Plus its a bit warmer. Not sure if these will even be deciding factors. Just trying to state all the facts.
-Joe
limpio as fukk
