Seafoamed...now Car Won't Start
If you ran too much you can hydro lock the motor.
you must not have used it right, I've heard nothing but good things from people who've used it
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
Originally posted by Mars_302
When you are at WOT when cranking, the engine goes into clear flood mode, and not fire the injectors.
Racing Integration
LHT Performance
Racing Integration
LHT Performance
Pull your plugs and dry them off, I bet they are wet. Install the plugs, hold your foot the floor and crank a lot. When you are at WOT when cranking, the engine goes into clear flood mode, and not fire the injectors.
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
i sea foamed my motor a couple of weeks, it runs smoother, idles smoother. when adding the sea foam i did the 1/3 in crank case, 1/3 in through brake booster and 1/3 in the tank it blew tons of smoke at first i had to rev it so it didnt stall. no problems at all
TR salesman..........
TR Balla Donor Supreme
on
I put it in the break booster...it started stuttering, then stalled...I tried to turn it back on, and it won't turn over....just checked the spark plugs, and they are ok...
you mixed it with brake fluid?.............if you put it in the master brake cylinder that has absolutly nothing to do with your car running. take it to a shop
that is a rare car you should be more careful with it.
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
-John
Aim: le lead
Cell: (813)843-8523
If you want to use something that cleans out the motor- run engine flush- but that could clog your oil pump- to clean the injectors- use GREASE LIGHTNING-
