Huge Problem
Old Dec 28, 2004 | 01:32 PM
JDMBlackGSR's Avatar
Gators Bitches!
Default Huge Problem
I am doing my engine tomorrow, meaning gaskets and seals, but also adding cams pistons and rods....my problem is, I have ITR pistons, and they dont fit on the Eagle Rods.
Are GSR and ITR Rods the same? Length, width, weight? Would I be able to use the GSR rods with ITR pistons? Need help quick. Thanks for the help.
Old Dec 28, 2004 | 03:49 PM
mtber's Avatar
Yes you can use GSR rods with ITR pistons.
Old Dec 28, 2004 | 04:13 PM
Gators Bitches!
thats what i thought, i just wanted to use the eagle...guess i will have to sell those.
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Dec 28, 2004 | 04:25 PM
brax90si's Avatar
i have heard of people taking some off the inside of the pistons to make the eagle rods fit.
-Braxton
Old Dec 29, 2004 | 03:56 AM
Punkinterviews's Avatar
Chavez Motorsports
-Braxton
No!!!! Go to either Engine Lab or Islies and have them cut the rod to make the piston fit and balance it! This is the best thing to do.
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Old Dec 29, 2004 | 06:52 AM
Frankie Figs's Avatar
Too Much is ALMOST Enough
i would get some high compression pistons and keep the rods, this would make a solid na setup and you could even throw a lil spray on it like a 50 shot
