Hitting rev limiter at 3500...
Old Dec 26, 2004 | 02:07 PM
Jaso0on's Avatar
Is now ballin!
Question Hitting rev limiter at 3500...
got a 93 b18a1 LS in my 91 DX hatch, i redid the whole car from headlights to taillights with a 91 Si harness, anyways, the car has been running great since the swap, and just recently it started to do it every now and then when its cold, but today, it warmed up to 180 degrees on the water temp guage, and its still jst bouncing off the rev limiter right exactly on 3500.. what all possibilities could this be, the damn car sounds like a rotary when i hit 3500, this is def. getting old fast.. any suggestions? thanks in advance!
-Jason
RIP Kevin (Slo_Si) Gonzalez - 09/13/2006
Old Dec 26, 2004 | 02:12 PM
Frankie Figs's Avatar
Too Much is ALMOST Enough
did you change the tach fluid? cuz that will make the ecu act retarded and give it a false reading. so the ecu thinks you're at redline and you're really not. I really have no idea
Old Dec 26, 2004 | 02:46 PM
Jaso0on's Avatar
Is now ballin!
So frankie, isnt the tach fluid in the jug next to the Veetek sauce?
No, but i just went outside and pulled all of my plugs to see if any were fouled out, none were.. I do have a missing valve cover gromet in #4 so that one was filled with oil, so i get a turkey baster and suck it all out, took that plug out and let the rest of the oil drain down, put all the plugs back in and the wires back on, cranked it up and drove it down the street, making a few slow 7k pulls and then one 8k pull and it ran perfect all the way. wtf is goin on, but i am getting a CEL, and throwing a code 43, all the info i have on that code is "fuel system" anymore thoughts?
Edit: 4300th post!
Old Dec 26, 2004 | 03:39 PM
Jaso0on's Avatar
Is now ballin!
shitty, nobody knows?
Old Dec 26, 2004 | 03:46 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
sounds like a wiring problem somewhere in the fuel system... that will cause the ecu to go into limp mode as a safety feature to preven lean conditions...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
Old Dec 26, 2004 | 04:40 PM
91Crx but i heard vtec's Avatar
All Socoms CAMOPIMPIN
check ur timing u might have jumped timing also wiring maybe bad distributer possible low on oil too good luck
DONT SLEEP's penis tastes soooooo good
Old Dec 26, 2004 | 05:01 PM
Jaso0on's Avatar
Is now ballin!
Oil is fine, timing is good, wiring MIGHT be the problem but i highly doubt it, i have no clue.. could one of my fuel injectors not be opening up, have a clogged fuel filter, or something like that? it isnt doing it anymore but i still dont like the fact that it DID it so im still gonna try and get to the bottom of this..
-Jason
Old Dec 26, 2004 | 08:31 PM
could be water damage to ur computer could be moister in the distributer theres alot of factors check basic stuff first good luck
Old Dec 26, 2004 | 08:53 PM
Trip's Avatar
Dramatic Lemur
I'm pretty sure it's your primary o2 sensor.
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
Old Dec 26, 2004 | 08:54 PM
haha good shit Trip wasnt paying attention
