Fix it or swap it?
My brother has a 97 Civic ex, and his axles need replacing, as well as the cv joints, and also the transmission needs a rebuild since the 5th gear and third gear grinds pretty much on every shift. Would you reccomend fixing these problems, or just swapping in a Ls?
Do not store up for yourselves treasures on earth, where moth and rust destroy, and where thieves break in and steal. But store up for yourselves treasures in heaven, where moth and rust do not destroy, and where thieves do not break in and steal. For where your treasure is, there your heart will be also.
--Matthew 6:19-21
--Matthew 6:19-21
Swap it... or buy a new tranny for around $150 and a set of axles from discount etc.
How much would I be looking at for a clean b18 swap?
--Matthew 6:19-21
--Matthew 6:19-21
you can find an ex tranny cheap, like 300 or less, and i was under the impression that the axles were cv joints....but those can be had brand new for around 160
much cheaper than a swap...however still slower..... it would be much more expensive to swap it ls's are great but you already have a d16 so just keep it and fix the axles and just get a different tranny its cheaper than a rebuild...then boost it or something if you want power
Alarm Crazy!
|| 1994 Honda del Sol vtec || B16a2 || 2 engines in garage one in car
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
how many miles are on the d by the way...and does it have any leaks ect? if so .....swap might be a cheaper alternative...like if rings are gone i would rip that bitch out and put a b in there for sure
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
It has almost 100k
--Matthew 6:19-21
--Matthew 6:19-21
that doesn't mean much for a honda, is there anything wrong with the engine, like does it smoke blue smoke under hard acceleration or does the head gasket leak, is there anything wrong with the engine?
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Nope, looks like were goinna fix it...Thanks bro.
--Matthew 6:19-21
--Matthew 6:19-21
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
Alarm Crazy!
w00t status ||
-John
Aim: le lead
Cell: (813)843-8523
