transmission case?
Old Nov 27, 2004 | 07:05 AM
Pharaoh's Avatar
Orlando Member
Default transmission case?
So long story short, hit a rock in the rain, look under my car, leaking something everywhere, next morning I look and its coming from transmission case, there are small cracks in it, well I JB welded what I could see and get to, but it stills leaks, not nearly as bad, but it still does, so anyway I was told I can get a new transmission case, but everywhere I call has no idea what I'm talking about... what can I do to fix my transmission
Old Nov 27, 2004 | 09:32 AM
mtber's Avatar
Sorry to hear the shitty news man.
You can buy a new tranny casing from acura direct, but its kinda pricey especially if you don't have a parts account with them.
Try calling Neal sutton or Collin (Guys that have tons of shit laying around b/c they do it for a living).
Old Nov 27, 2004 | 09:40 AM
rangcrx's Avatar
engine building &best
if its on the bottom to Jbweld it you would have to take it off so the jbweld can set into and on the crack cause it will drip off and not set right if its upside down hd the same problem someone tightened there drain with a impact and got like a 3 in crack and tried to use it so then we took it off and did it has not peeled off or leaked in 8months and its run hard with Lsd in it
i love AUTOZONE
Old Nov 27, 2004 | 04:46 PM
ugly86integra's Avatar
Chuck aka Woody
the big thing is to get the tranny turned up so you can get all the oil away from the crack. it has to be very clean before the jb weld can bond properly! use brake cleaner to clean the crack very good, then blow it out with an air line. also use qwick jb weld, not the original kind! it works much better! if ya get the oil out and get it VERY clean, it'll work great!!! the only other cheap option is get a case from a core tranny at the junk yard, but if ya dont know how to build a tranny, you'll be havin some problems. lol the jb should work great though! oh yeah, since ya already tried it, make sure you get all of the old jb out too!!!!!
NO EXCUSES for my lil FWD! Cmon RWD's n AWD's, lets DIG!
STEISS RACING all the way
HONDA ENGINES from oem to EXTREEM
www.myspace.com/streetracin_cwby
http://www.facebook.com/#!/profile.php?id=1433200141
Old Nov 28, 2004 | 04:51 PM
Pharaoh's Avatar
Orlando Member
how hard is it to take the tranny case off?
Old Nov 29, 2004 | 06:46 AM
BERT-O's Avatar
yO!
which one, the "base" of the "top cover"
Old Dec 2, 2004 | 11:53 AM
cxcivic's Avatar
swapin' Hondas since '95
Default Re: transmission case?
call dave at Ferman Acura 813 931 6262, he will know what you need. If you are interested, I charge $150 to rebuild trannies, you pull it out the car. -Neal
K20turbo EG hatch 10.49@136
street tuned by NS RACING
??check engine light?? Tranny grinds??I fix'em!!
I MAKE HOUSE CALLS!!
SAME DAY ECU CHIPPING
I <3 WIRES
NS RACING (813)842-5517
chipped P28's $125
http://www.youtube.com/watch?v=nbsSp...a_player<br />
http://www.youtube.com/watch?v=koGfpMAvfWk
http://www.facebook.com/neal.sutton.750
Old Dec 3, 2004 | 07:37 AM
KJ's Avatar
KJ
bored at work
Have it tig welded. I cracked the oil sender port on my block and no matter what kind of epoxy weld I tried no luck. I cleaned it real well and tigged it up and have not had a problem since.
Remove the tranny and then find someone really good at aluminum welding. Will be alot cheaper than paying for a new tranny case.
Tip: if you are going to have it welded, drill a small hole at each end of the crack to keep the crack from growing under the heat.
