crank balancing
Old Nov 16, 2004 | 10:08 AM
LIL_G's Avatar
Default crank balancing
is it worth getting a stock b16a crank ballanced or pay the extra buck and get a aftermarket one ? whats the average cost of a stock crank being ballanced, the reson i ask is cause i have wisco pistons eagle rods and lightened flywheel , what do you think
Old Nov 16, 2004 | 10:42 AM
MacGruber's Avatar
MaDe Of MoNeY
use the stock b16 because they are forged from honda and just have them look it over and make sure everything is in spec and have them balance it. They usually ask for the harmonic balancer and flywheel at the time of the balancing to properly balance. At least I know engine lab does.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Nov 16, 2004 | 10:44 AM
99B16Si's Avatar
crank balancing generally runs about $200 which is a whole lot cheaper than an aftermarkey crank, so i think its an easy choice
