cam difference
chris chavez has a pair for sale (punkinterviews) he could tell you
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
KJ built
ALPHA TUNED
the newer itr cams have almost the same profile as ctr's
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
Guest
Posts: n/a
Exhaust cam profiles are exactly the same as the CTR , intake cam will be more aggresive by a few degrees which will yield anywhere between 3-5hp.
ITR int cam part # 14111-p73-j00
ITR exh cam part # 14121-p73-j00
CTR int cam part # 14111-pct-000
CTR exh cam part # same as ITR 14111-p73-j00
JDM ITR int specs 240 deg of intake duration, 11.5mm lift
JDM ITR exh specs 235 deg of duratio ,10.5mm of lift
ITR have 25 degrees of overlap
CTR int specs 243 degs of duration and 28 degrees of overlap.
figures were obtained from honda-tech
Honestly, the difference is minimal, I wouldnt waste my time upgrading to anything less then a skunk2 stage 1 cam or a toda spec a.
Manufacturer Intake Exhaust
Lift Duration Lift Duration
HONDA OEM Civic Type R 11.5mm 243 @ 1mm 10.5 mm 235 @ 1mm
HONDA OEM Integra Type R 11.5 mm 240 @ 1mm 10.5 mm 235 @ 1mm
Buddy Club Spec III 11.59mm 304 10.71mm 294
Buddy Club spec IV 12.3mm 306 11.8mm 302
Crower 63400 10.69 mm 244 @ 1mm 9.83 mm- 231 @ 1mm
Crower 63401 11.38 mm 249 @ 1mm 10.54 mm 240 @ 1mm
Crower 63401T 11.81 mm 240 @ 1mm 11.30 mm, 237 @ 1mm
Crower 63402 11.84 mm 258 @ 1mm 11.84 mm 251 @ 1mm
Crower 63402A 11.84 mm 246 @ 1mm 11.81 mm 239 @ 1mm
Crower 63403 12.04 mm 267 @ 1mm 11.84 mm 257 @ 1mm
Jun Type 1 10.9 mm 265.3 @ 1mm 10.0 mm 268 @ 1mm
Jun Type 2 12.0 mm 266.6 @ 1mm 10.9 mm 265.3 @ 1mm
Jun Type 3 12.0 mm 265.3 @ 1mm 11.5 mm 265.3 @ 1mm
Rocket Motorsports M20 11.5 274 11.5 274
Rocket Motorsports M21 11.6 274 11.6 274
Rocket Motorsports M22 12.1 284 12.1 284
Rocket Motorsports M24E 12.7 303 12.7 303
Rocket Motorsports M24X 12.7 298 12.7 298
Rocket Motorsports M25 12.1 310 12.1 310
Rocket Motorsports M25E 13.25 316 13.25 316
Spoon Sports 11.53 mm 256 @ 1mm 11.13 mm 245 @ 1mm
Skunk 2 stage1 11.58 mm 252 @ 1mm 10.9 mm 249 @ 1mm
Skunk2 stage 2 12.3 mm 266 @ 1mm 11.8 mm 262 @ 1mm
Skunk2 stage 3 12.8 mm 273 @ 1mm 11.5 mm 273 @ 1mm
Toda Spec A 11.6 mm 250 @ 1mm 11.2mm 240 @ 1mm
Toda Spec B 12 mm 255 @ 1mm 12 mm 245 @ 1mm
Toda Spec C 12.5 mm 255 @ 1mm 12.5 mm 255 @ 1mm
Toda Spec D (eric's racing) 12.9 mm 305 11.9mm 315
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
